ikonuk's avatar
ikonuk
Guide
May 15, 2017
CPU Temperature on a RN102 running OS 6.6.1
The temperature gage shows 153 deg F (image is attached). Is this normal.
It is running OS 6.6.1, no apps installed, disk spin down is ON.
Any advice would be appreciated.
I. Konuk
PS: When is 6.7.1 expected tRN102-PerformanceStatus-OS6-6-1_05152017_IKonuk.JPGo be avialable for my system (RN102) via the Update Server?
  • Retired_Member's avatar
    Retired_Member
    May 16, 2017
    yup, sometimes cpu gets pretty hot in rn10x depending on situation. i would set the fan to "cool".
    Retired_Member
    • ikonuk's avatar
      ikonuk
      Guide
      Thanks very much. It dropped to 127 deg F after I switched to "cool" mode.
ProSupport for Business
