bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Apr 02, 2016Guru - Experienced User
Have you tried the putty tunnel? It is stil working for me.
It is helpful to make C:\ProgramData\CrashPlan\.ui_info read-only - otherwise the PC Crashplan UI tends to re-write the token when it starts up.
tony359
Apr 02, 2016Apprentice
Hi Stephen,
Yes, I managed to have it working again via putty but it was working without before. And I can't remember what I did to have that working.
It would be a good time to create the new step by step guide :)
- StephenBApr 02, 2016Guru - Experienced User
I think the basic trick you are looking for is described here: https://www.liquidstate.net/how-to-manage-your-crashplan-server-remotely/
Adding serviceHost=nasipaddress in ui.properties on the pc, and changing the servicehost from 127.0.0.1 to 0.0.0.0 on the NAS
I agree but if I took it on I'd needed to do a fresh install to check it - not something I'm prepared to do :-)
- tony359Apr 03, 2016Apprentice
No worries, I've just freshly reinstalled mine! :)
Thanks
Somehow it did not work for me. The fact that the token was changed every time did not help and after wasting tons of time over the past few days I'm giving up now! It works with putty, happy days.
Why not making it simpler!!
- StephenBApr 03, 2016Guru - Experienced User
I'm ok with using putty myself. The first thing I do is tail the backup_file and history log, and I don't even launch the gui unless something looks off there..
- JeremyP1May 07, 2016Aspirant
What you probably did was edit <install dir>/conf/my.service.xml and change the serviceHost line to
<serviceHost>0.0.0.0</serviceHost>
so that it listens for the UI on all ports. You still need to edit the .ui_info on the PC file to point to it as per the headless instructions and use the actual ip of the ReadyNAS instead of the localhost.
4243,00000000-0000-0000-0000-000000000000,192.168.1.x <port>,< Token >,<IP of ReadyNAS>
Adding serviceHost=nasipaddress as suggested isn't going to work (not on 4.6 anyway) as somewhere down the line there was a change in the format for the config file that handles this.
Has everyone here used WhoCares_'s (Stephan's) glibc addon to get this working? Has anyone run into a bunch of apt-get dependency problems from it? I tried his addon twice and it essentially prevents apt-get from being used because of dependency issues. As of now, I got CrashPlan running with the EJRE installer and a patch for the inotify_init1 error. This lets me stay on the older glibc and keep my apt-get working. As well as allow me to install and compile various things I needed running on the NAS.
inotify_init1() was added in Linux 2.6.27; library support was added to glibc in version 2.9. WhoCares_'s addon installs version 2.13. I wonder if installing an older version with support for inotify_init1 would keep things working. I may give this a shot after a much needed break from dealing with this and after making a backup of the OS partition.
- StephenBMay 08, 2016Guru - Experienced User
I installed it some time ago, and had no problems with NAS operation or crashplan since. But I normally don't use apt-get so I wouldn't run into the dependancy issues. Perhaps WhoCares_ will comment.
CrashPlan upgrades now install Java - I was running 1.8 from ejre, but it decided to install 1.7 as well..
- jplee3Jul 28, 2016Apprentice
Has anyone had issues with Crashplan auto-upgrading and completely botching their installation on the Readnas? This has happened to me twice now. I go through the setup and workarounds to get CP up and running and it works really well up until the point that CP pushes an automatic update. It's getting old really fast, and I don't think there's a way to disable auto-updates. Seems CP updates don't like what was done as far as manually changing libjna files and also using the native JRE 1.7 that I installed with apt... what ends up happening is that the update "half-completes" and leaves CP in a broken state where the /usr/local/crashplan/lib directory is completely wiped out... anyone else notice this and have a workaround?
- tony359Jul 28, 2016Apprentice
Hi
I haven't touched mine for a long while now. I receive notifications from CP every week so it's working.
Maybe it's better if you leave the installer using its own Java. I cannot remember whether the guide is mentioning that but when I first started looking into that it seemed that Java had to be manually installed - but the setup is copying its own version instead.
Have a look if you can remove the global Java - unless you need it - and maybe that would work when it updates. Also, can you find any logs that tell you what happened?
It seems a lot of stuff was wiped out, and not much info in the logs as to what exactly happened... or maybe I just don't know how to interpret them :)
I'll have to investigate some of those things - not as familiar with Java setups in Linux and am a bit rusty since I've been away from Linux in general for a while now and only dabble in it. I'll review the steps in OP's post, as the steps I did to setup CP were probably a bit different.
EDIT: here's the log (partial):
TARGETDIR=/usr/local/crashplan
BINSDIR=/usr/local/bin
MANIFESTDIR=/usr/local/var/crashplan
INITDIR=/etc/init.d
RUNLVLDIR=/etc/rc5.d
INSTALLDATE=20160528
APP_BASENAME=CrashPlan
DIR_BASENAME=crashplan
JRE_X64_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7-linux-x64.tgz
JRE_I586_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgzJAVACOMMON=/usr/bin/java
Sourcing ../../install.vars...
Found INITDIR=/etc/init.d...
Current CrashPlan Backup Engine:
root 1784 1 9 Jun28 ? 1-06:31:02 /usr/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
Stopping using /etc/init.d/crashplan...
Stopping CrashPlan Engine ... OK
Ensuring the UpgradeUI is not running.
UpgradeUI is shut down.
JAVACOMMON is set: /usr/bin/java
Current Java Version: 1.7
The Current java is not compatible. Embedding a compatible version.
Download JVM from http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
downloading the JRE using /usr/bin/wgetconverted 'http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:21-- http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Resolving download.code42.com (download.code42.com)... 216.17.8.19
Connecting to download.code42.com (download.code42.com)|216.17.8.19|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz [following]
converted 'https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:21-- https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Connecting to download.code42.com (download.code42.com)|216.17.8.19|:443... connected.
Location: https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz [following]
converted 'https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:23-- https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Resolving download2.code42.com (download2.code42.com)... 216.17.8.57
Connecting to download2.code42.com (download2.code42.com)|216.17.8.57|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 48547492 (46M) [application/octet-stream]
Saving to: 'jre-7-linux-i586.tgz'....
Java Installed.
Unpacking remaining upgrade files
currentDir=/usr/local/crashplan/upgrade/1435813200470_344.1468263488565
upgrade.sh: line 214: cpio: command not found
Removing existing app files...
Adding updated files...
32 bit version detected, using 32 bit electron.
Replacing CrashPlanDesktop
`scripts/CrashPlanDesktop' -> `../../bin/CrashPlanDesktop'
Replacing CrashPlanEngine
`scripts/CrashPlanEngine' -> `../../bin/CrashPlanEngine'
Replacing run.conf
`scripts/run.conf' -> `../../bin/run.conf'
Replacing root app launcher file...
Replacing /usr/share/applications/crashplan.desktop with scripts/CrashPlan.desktop AS /usr/share/applications/crashplan.desktop...
removed `/usr/share/applications/crashplan.desktop'
`scripts/CrashPlan.desktop' -> `/usr/share/applications/crashplan.desktop'
Finished removing user launcher files...
Restarting Service
Could not find JAR file /usr/local/crashplan/bin/../lib/com.backup42.desktop.jar
Service Restart Complete - jplee3Jul 28, 2016Apprentice
Stephen, I'm running on the RN204 on 6.5.1... maybe the way I installed it is not right. But since it's an ARM processor, I think I have to do some hackey workarounds to get it working - like apt installing various packages and replacing the libjna.jar file in /usr/local/crashplan/lib - I don't think the CP upgrade process/script likes this and ends up botching the installation during the auto-upgrade process. Wish there were a way to turn off auto-upgrade so I can do it myself.
