JimTurkey
Sep 27, 2021Guide
Switches for Dummies
In our bedroom, wi-fi is the weakest in the house. Luckily, we have a hard-wired ethernet port behind the TV that I was thinking we could hook up. However, that is only 1 port and I'd like to hook up the TV, cable box, and computer which would require at least 3 ports.
Is a switch the best option?
A simple unmanaged switch is a great plan.
Pretty much plug and play.
I'd pay the little extra to get a gigabit one.
usually you can get a 5-8 port gigabit for around that $20-30
Which one would you recommend?
We have 1000 Mbps internet.
- plemansGuru - Experienced UserPretty much all unmanaged gigabit switches should do the job for you. Pick one that has the ports you need and the looks you want.
