bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
jplee3
Jul 28, 2016Apprentice
Has anyone had issues with Crashplan auto-upgrading and completely botching their installation on the Readnas? This has happened to me twice now. I go through the setup and workarounds to get CP up and running and it works really well up until the point that CP pushes an automatic update. It's getting old really fast, and I don't think there's a way to disable auto-updates. Seems CP updates don't like what was done as far as manually changing libjna files and also using the native JRE 1.7 that I installed with apt... what ends up happening is that the update "half-completes" and leaves CP in a broken state where the /usr/local/crashplan/lib directory is completely wiped out... anyone else notice this and have a workaround?
tony359
Hi
I haven't touched mine for a long while now. I receive notifications from CP every week so it's working.
Maybe it's better if you leave the installer using its own Java. I cannot remember whether the guide is mentioning that but when I first started looking into that it seemed that Java had to be manually installed - but the setup is copying its own version instead.
Have a look if you can remove the global Java - unless you need it - and maybe that would work when it updates. Also, can you find any logs that tell you what happened?
- jplee3Jul 28, 2016Apprentice
It seems a lot of stuff was wiped out, and not much info in the logs as to what exactly happened... or maybe I just don't know how to interpret them :)
I'll have to investigate some of those things - not as familiar with Java setups in Linux and am a bit rusty since I've been away from Linux in general for a while now and only dabble in it. I'll review the steps in OP's post, as the steps I did to setup CP were probably a bit different.
EDIT: here's the log (partial):
TARGETDIR=/usr/local/crashplan
BINSDIR=/usr/local/bin
MANIFESTDIR=/usr/local/var/crashplan
INITDIR=/etc/init.d
RUNLVLDIR=/etc/rc5.d
INSTALLDATE=20160528
APP_BASENAME=CrashPlan
DIR_BASENAME=crashplan
JRE_X64_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7-linux-x64.tgz
JRE_I586_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgzJAVACOMMON=/usr/bin/java
Sourcing ../../install.vars...
Found INITDIR=/etc/init.d...
Current CrashPlan Backup Engine:
root 1784 1 9 Jun28 ? 1-06:31:02 /usr/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
Stopping using /etc/init.d/crashplan...
Stopping CrashPlan Engine ... OK
Ensuring the UpgradeUI is not running.
UpgradeUI is shut down.
JAVACOMMON is set: /usr/bin/java
Current Java Version: 1.7
The Current java is not compatible. Embedding a compatible version.
Download JVM from http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
downloading the JRE using /usr/bin/wgetconverted 'http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:21-- http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Resolving download.code42.com (download.code42.com)... 216.17.8.19
Connecting to download.code42.com (download.code42.com)|216.17.8.19|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz [following]
converted 'https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:21-- https://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Connecting to download.code42.com (download.code42.com)|216.17.8.19|:443... connected.
Location: https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz [following]
converted 'https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (ANSI_X3.4-1968) -> 'https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz' (UTF-8)
--2016-07-11 11:58:23-- https://download2.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
Resolving download2.code42.com (download2.code42.com)... 216.17.8.57
Connecting to download2.code42.com (download2.code42.com)|216.17.8.57|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 48547492 (46M) [application/octet-stream]
Saving to: 'jre-7-linux-i586.tgz'....
Java Installed.
Unpacking remaining upgrade files
currentDir=/usr/local/crashplan/upgrade/1435813200470_344.1468263488565
upgrade.sh: line 214: cpio: command not found
Removing existing app files...
Adding updated files...
32 bit version detected, using 32 bit electron.
Replacing CrashPlanDesktop
`scripts/CrashPlanDesktop' -> `../../bin/CrashPlanDesktop'
Replacing CrashPlanEngine
`scripts/CrashPlanEngine' -> `../../bin/CrashPlanEngine'
Replacing run.conf
`scripts/run.conf' -> `../../bin/run.conf'
Replacing root app launcher file...
Replacing /usr/share/applications/crashplan.desktop with scripts/CrashPlan.desktop AS /usr/share/applications/crashplan.desktop...
removed `/usr/share/applications/crashplan.desktop'
`scripts/CrashPlan.desktop' -> `/usr/share/applications/crashplan.desktop'
Finished removing user launcher files...
Restarting Service
Could not find JAR file /usr/local/crashplan/bin/../lib/com.backup42.desktop.jar
Service Restart Complete
