bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Dec 08, 2016Guru - Experienced User
Try 127.0.0.1 on the RN - that's what's in my file.
tony359
Dec 08, 2016Apprentice
Thanks Stephen
It was like that, then I tried 192.
I put it back to 127.0.0.1 but no luck.
- StephenBDec 08, 2016Guru - Experienced User
Some less likely things:
On the PC the .ui_info file should be in c:\ProgramData\CrashPlan
On the ReadyNAS it should be in /var/lib/crashplan. That copy needs to be edited preserving linux text file conventions (for instance notepad++).
You might also want to check ui.properties in c:\program files (x86)\CrashPlan\conf. ServiceHost and ServicePort lines should be commented out (begin with a #)
- tony359Dec 08, 2016Apprentice
yes I'm using notepad++
It's all as you suggest. Only thing is that the .ui_info on the NAS has 192.168.0.10 as address. If I change it to 127.0.0.1 and restart the service, it goes back to 192.168.0.10... and the token changes every time.
It sounds like it is connecting with the crashplan service on the PC.
I'm not seeing anything wrong with your configuration though.
