bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
depasseg
May 04, 2012Aspirant
Great writeup. I added a couple things - like installing Nano rather than using vi and also including instructions to configure the headless monitoring:
* Install RootSSH Add-on
* Reboot
* SSH as root
* run: Apt-get update
* run: apt-get install nano (viewtopic.php?f=36&t=42794)
* echo deb http://archive.debian.org/debian-backports etch-backports main non-free >> /etc/apt/sources.list
* (additional info comes from: viewtopic.php?f=61&t=18139&hilit=CrashPlan&start=30)
* run: apt-get update
* run: dpkg-reconfigure debconf and select the "Dialog" option (1) and "Medium" prompt level (3) This is necessary so that the sun JRE license agreement can be displayed and accepted
* run: apt-get install sun-java6-jre
* run: dpkg-reconfigure debconf and select the "Dialog" option (1) and "Noninteractive" and "High" prompt level (3)
* run: wget http://download.crashplan.com/installs/ ... _Linux.tgz
* run: tar -xvf CrashPlan_3.2.1_Linux.tgz
* run: cd CrashPlan-install
* run: ./install.sh
* Choose the following settings:
Do you accept and agree to be bound by the EULA? (yes/no) yes
What directory do you wish to install CrashPlan to? [/usr/local/crashplan]
/usr/local/crashplan does not exist. Create /usr/local/crashplan? (y/n) [y]
What directory do you wish to link the CrashPlan executable to? [/usr/local/bin]
What directory do you wish to store backups in? [/usr/local/var/crashplan] /c/backup/crashplan-local
What directory contains your SYSV init scripts? [/etc/init.d]
What directory contains your runlevel init links? [/etc/rc2.d]
Your selections:
CrashPlan will install to: /usr/local/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /c/backup/crashplan-local
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Is this correct? (y/n) [y] y
Unpacking /./CrashPlan_3.2.1.cpi ...
37915 blocks
Starting CrashPlan Engine ... Using standard startup
OK
CrashPlan has been installed and the Service has been started automatically.
Press Enter to complete installation.
* run: nano /usr/local/crashplan/conf/my.service.xml
* On the line that says ServiceHost. Replace 127.0.0.1 with IP of the NAS (the one from your LAN like 192.168.1.100) and then save the file and exit nano
* run: /usr/local/crashplan/bin/CrashPlanEngine restart
* On your computer (the one you want to control your NAS backups from), look for a file called ui.properties in c:\Program Files\CrashPlan\conf
* Edit the file and uncomment (delete the #) the serviceHost line and replace 127.0.0.1 with the IP of your NAS (for instance 192.168.1.100).
* Start Crashplan client on your computer and login
* In Crashplan, go to Destinations and click select. Choose "backup/crashplan/crashplan-local"
* Go to Settings -> "Inbound from other computers" and click Configure
* Note Backup code to use for friends and other computers
* Change "Default backup archive location" to /c/backup/crashplan-inbound (note this folder must be created ahead of time)
* Remove WAN speed throttling
* Enable Backup Sets
* Create a System Files Set (to crashplan central and crashplan-local (folder)) and a Media Set (for /c/media)
Additional helpful links:
* http://linuxhints.blogspot.com/2011/02/ ... dless.html
* http://innerfusion.tumblr.com/post/6168 ... in-7-steps
