bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
May 25, 2012Guru - Experienced User
Use bishoptf's original instructions (based on Crashplan's guide: http://support.crashplan.com/doku.php/h ... ess_client)
kc1 wrote: Just wondering how to make it work so that I can control 2 NASs on my lan? The easiest way is probably to install the desktop app on another pc with the IP of the 2nd NAS in the ui.properties file, but I'm just wondering if those familiar with crashplan know of a way to make it work from one PC?
In short, leave the serviceHost line commented out in ui.properties and set servicePort to 4200 instead.
Then set up ssh profiles in putty for each NAS. Connect to the NAS you want to manage with Putty, then launch the crashplan client. When switching to the other NAS you exit the client, change the putty connection, and launch it again. (failing to exit the client is not fatal, it will error out).
