bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
mdgm-ntgr
May 25, 2012NETGEAR Employee Retired
Use a free program called PuTTy to SSH in.
Choose SSH and enter the host 2.2.2.2 (replace the 2.2.2.2 with the actual IP address of the device).
Then go to the menus on the side panel. One of the options there will allow you to do the tunnel configuration.
Source Port: 4200
Destination: localhost:4243
Then click Add (don't forget to do this step)
then connect.
Source Port: 4200
then connect.
