bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
f41yaz
Jul 26, 2012Aspirant
StephenB wrote: Is this the guide you followed: http://www.readynas.com/forum/viewtopic.php?f=4&t=61152&hilit=crashplan#p342781
yes thats the guide i followed.
How do i check that crashplan is correctly installed on my nas...also what is the command to completely remove crashplan for me to reinstall it again.
when i change the ui.properties file codes and than open putty and open crash plan...i get the error message that its unable to connect to the backup engine on CP.
thanks for your support
