bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
f41yaz
Jul 26, 2012Aspirant
StephenB wrote: Your copy/paste is not keeping the lines separate.
If ui.properties is configured correctly, when you launch crashplan without putty running you will see the splash screen for quite a while. Then you will see "unable to connect to the backup engine, retry?" If you are not seeing that error, then we need to fix that before we move on.
i just rebooted pc and ans again and its saying "unable to connect to the backup engine, retry?".
even with putty open in background
