bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Aug 24, 2012Guru - Experienced User
You might want to engage CrashPlan support (and post on their forum), They won't do much with the headless configuration, but I think your issue is not related to the fact you are headless. I see some cases where the service disconnects in my log, but I am not seeing the continuous "Crashplan Started" entries that you are seeing.
In the meantime, you can look at the logs in /usr/local/crashplan/log. Note there are also some logs in /usr/local/crashplan/bin. Also, if you click on the house in the upper right corner of the client, you will get a list of commands (which you can enter at the top of the window). There is a way to adjust the logging level, but regrettably the usage hint is not informative.
You could also be running out of virtual memory. If you look at /usr/local/crashplan/bin/run.conf you will see an -Xmx512m option. You can try doubling that to -Xmx1024m and see if that helps.
