bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
jamestx10
Aug 24, 2012Aspirant
/usr/local/crashplan/bin
Was full of restart logs that all look pretty much the same:
Nothing jumped out to me (non linux guy) in the /usr/local/crashplan/log files. I decided to try your Virtual memory change in /usr/local/crashplan/bin/run.conf
DEFAULT File:
Modified File:
So far that seems to be the issue. I have the client connected for 30 Min now without a crash and the backup is running.
Fri Aug 24 11:33:08 CDT 2012 : /usr/local/crashplan/bin/restart.sh
Fri Aug 24 11:33:08 CDT 2012 : APP_BASENAME=CrashPlan
Fri Aug 24 11:33:08 CDT 2012 : DIR_BASENAME=crashplan
Fri Aug 24 11:33:08 CDT 2012 : Stopping using ./CrashPlanEngine...
Stopping CrashPlan Engine ... Still running, killing PID=16820 ...
OK
Fri Aug 24 11:33:08 CDT 2012 : Sleeping 10 seconds...
Fri Aug 24 11:33:18 CDT 2012 : Starting using ./CrashPlanEngine...
Starting CrashPlan Engine ... Using standard startup
OK
Fri Aug 24 11:33:18 CDT 2012 : New Service Process below:
Fri Aug 24 11:33:18 CDT 2012 : Exiting restart script
DEFAULT File:
SRV_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx512m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
GUI_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanDesktop -DappBaseName=CrashPlan -Xms20m -Xmx512m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
Modified File:
SRV_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
GUI_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanDesktop -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
