bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
May 06, 2013Guru - Experienced User
Squazz wrote:
StephenB wrote: Crashplan starts automatically on my Pro-6.
Did you remember to edit ui.properties?
I have edited a little, ATM the file looks like this:#Fri Dec 09 09:50:22 CST 2005
serviceHost=192.168.1.66
#servicePort=4243
I have been wondering if I schould althe the serviceport til 4200?
Change it to
#serviceHost=192.168.1.66
servicePort=4200
(specify the new service port, but not the servicehost).
If you look at the putty configuration (tunnels) you should see
L4200 localhost:4243in the forwarded ports box.
