bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Squazz
May 06, 2013Aspirant
StephenB wrote:
Change it to#Fri Dec 09 09:50:22 CST 2005
#serviceHost=192.168.1.66
servicePort=4200
(specify the new service port, but not the servicehost).
If you look at the putty configuration (tunnels) you should seeL4200 localhost:4243in the forwarded ports box.
That did the trick! Yes! Thanks :)
Update:
Even though it worked, I now can't get the UI working on my desktop :/ It's like it's constantly trying to connect to my NAS, but is getting refused because I'm tunneling with putty.
I have tried resetting & out-commenting the servicePort.
The problem is solved by reinstalling CP on my desktop, but I'm curious to what I could be doing wrong :)
