bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
bishoptf
Jun 10, 2013Aspirant
InterClaw wrote:
bishoptf wrote: Bought a ultra some months ago and finally just got it up and running, needed to get crashplan back up and running..I went through the steps and they still work, thought there might be a java 7 jre but could not find one, at some point that might become an issue. If anyone has any comments or updates let me know and I will update the orginal post if I can.
You can check out a post by me on the previous page for at least one way to update to java 7. :)
I missed that one, looks like it works, I stopped java, downloaded the embedded version which required me to register, I was doing a wget and didn't realize it wasn't downloading the real file, grrr oracle, but after messing around with that and finally getting the real file, it worked straight away. Not sure if they will keep the addon up to date but it does install the one you download.
I was looking at using another debian repo but it wanted to pull in a whole bunch of other stuff, upside would be they would keep it up to date but this appears to be cleaner for now.
I will think about updating the original post if possible and add some words about this method. Saves quite a few steps let me see what I can do, I'm a nix guy so cli is easy peasy for me, but I understand not the mainstream.
