bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
joepez
Sep 14, 2013Aspirant
Hopefully someone can help me out with this problem.
I tried to follow the steps from the first post, but on a 516 running 6.1.2 the FrontView installer refuses to recognize the EJRE installer as a valid pacakge.
So I tried an alternative method found here (http://www.shasam.net/blog/2012/3/21/crashplan-on-the-netgear-readynas-x86.html), but there is no apt-get for the Sun Java 7 packages, so I installed the OpenJDK 7 package.
Install went fine for OpenJDK 7 . I run java -version and get the following:
I followed through on the rest of the steps and download and extracted the latest CrashPlan client (3.5.3). When I try and run install.sh I get the following error message:
I know Java is installed, everything appears to be there, but I'm stumped.
Can anyone help me figure out what's missing?
java version "1.7.0_21"
OpenJDK Runtime Environment (IcedTea 2.3.9) (7u21-2.3.9-1ubuntu1)
OpenJDK 64-Bit Server VM (build 23.7-b01, mixed mode)
Error: Could not find or load main class com.code42.utils.JavaEnvironment
The current version of Java () is incompatible with CrashPlan.
Please install one of the following version of the Sun JRE or OpenJDK: 1.5 1.6 1.7
