bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Jan 07, 2014Guru - Experienced User
Maybe check to see if the OS is swapping, or if there is a Netgear process hogging the CPU.
I have deduplication set to "minimal" in advanced backup options, and compression set to "off".
Also check your network settings and make sure the bandwidth limits aren't set.
