bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
dsm1212
Feb 13, 2014Apprentice
What is currently in /c/crashplan? Maybe that is where you installed crashplan? I never created that directory in my pro6 setup. If it is your install directory I wouldn't open permissions on that. The easiest thing to do is:
1. create a new share called backups and a subdirectory inside that for each computer you are backing up
2. add permissions for the share
3. copy your seed to that computer's subdirectory.
4. add that directory to your crashplan list of directories to back up.
steve
steve
