bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Feb 21, 2014Guru - Experienced User
You have ssh enabled on the NAS, and are logged in with Putty? Also, you need to forward a port in the putty configuration, and set up the client configuration to use that port.
I suspect one of those steps is not done correctly.
