bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Feb 21, 2014Guru - Experienced User
Sure. You can do that by entering
InterClaw wrote: Maybe also check that the engine is actually running on the NAS?
ps $(pidof java)
The status should come back with "-Dapp=CrashPlanService"
Though I think the client setup is far more likely to be the problem.
