bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
SteveMathews
Oct 06, 2014Guide
Hi
I think I now have successful installed java having found some instructions on p10 of this forum.
but now when i try to run crashplan install i get the following message
Any suggestions for where I'm going wrong?
thanks
java version "1.7.0_65"
OpenJDK Runtime Environment (IcedTea 2.5.1) (7u65-2.5.1-5~deb7u1)
OpenJDK 64-Bit Server VM (build 24.65-b04, mixed mode)
Welcome to the CrashPlan Installer.
Press enter to continue with installation.
Validating environment...
detected root permissions
mkdir: cannot create directory `./lib': File exists
cpio: unrecognized option '--no-preserve-owner'
BusyBox v1.20.2 (Debian 1:1.20.0-7) multi-call binary.
Usage: cpio [-dmvu] [-F FILE] [-H newc] [-tio] [EXTR_FILE]...
Extract or list files from a cpio archive, or
create an archive using file list on stdin
Main operation mode:
-t List
-i Extract EXTR_FILEs (or all)
-o Create (requires -H newc)
-d Make leading directories
-m Preserve mtime
-v Verbose
-u Overwrite
-F FILE Input (-t,-i,-p) or output (-o) file
-H newc Archive format
Error: Could not find or load main class com.code42.utils.JavaEnvironment
'/tmp' not writable.
thanks
