bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
jamminontoast
Oct 29, 2014Aspirant
I've tried to follow the initial guide however am running into problems; i must of mistyped a port forwarding and now do not know how to get rid of it.
Updated my ui.properties without any issues
SSH into the nas and run tried to forward the port using root
Used to the following command to find if it was forwarded okay however only see 4200 and not 4243
Does any one know how to delete the 4200 forwarding?
Output as per Crashplan website is
Output should look like this:
#Fri Dec 09 09:50:22 CST 2005
#serviceHost=127.0.0.1
servicePort=4200
#pollerPeriod=1000 # 1 second
#connectRetryDelay=10000 # 10 seconds
#connectRetryAttempts=3
NAS:~# ssh -f -L 4200:localhost:4243 [email protected] -N
[email protected]'s password:
bind: Address already in use
channel_setup_fwd_listener: cannot listen to port: 4200
Could not request local forwarding.
SmellyNAS:~# netstat -na | grep LISTEN | grep 4
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN
tcp 0 0 5.171.174.232:6887 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:4200 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:44490 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:842 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
tcp6 0 0 :::548 :::* LISTEN
tcp6 0 0 ::1:4200 :::* LISTEN
tcp6 0 0 :::443 :::* LISTEN
unix 2 [ ACC ] STREAM LISTENING 3421 /var/run/acpid.socket
username$ netstat -na | grep LISTEN | grep 42
tcp4 0 0 *.4242 *.* LISTEN
tcp4 0 0 127.0.0.1.4243 *.*
