bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
jamminontoast
Nov 03, 2014Aspirant
StephenB wrote:
Did you try launching crashplan on the client PC and see if it connects to the crashplan server when putty is launched/logged in?
Thanks for the tip re: not showing the ports forwarding when setting Putty
So i followed your instructions...
Using OSX, launch Putty and setting the port forwarding i can see it in the logs
2014-11-04 10:11:58 Initialised AES-256 SDCTR client->server encryption
2014-11-04 10:11:58 Initialised HMAC-SHA1 client->server MAC algorithm
2014-11-04 10:11:58 Initialised AES-256 SDCTR server->client encryption
2014-11-04 10:11:58 Initialised HMAC-SHA1 server->client MAC algorithm
2014-11-04 10:12:04 Sent password
2014-11-04 10:12:04 Access granted
2014-11-04 10:12:04 Opening session as main channel
2014-11-04 10:12:04 Opened main channel
2014-11-04 10:12:04 Local port 4200 forwarding to localhost:4243
2014-11-04 10:12:04 Allocated pty (ospeed 38400bps, ispeed 38400bps)
2014-11-04 10:12:04 Started a shell/command
Launching CrashPlan on PC - Says 'Unable to connect to backup engine'.
>>I'd assume this is probably NOT correct as the port *should* be forwarded?
- From here: if i run the linux command to port forward in putty... The netstat command still shows only 4200 and not 4243. And If i launch CrashPlan on PC - still says 'unable to connect to backup engine'.
Note: I used my NAS's IP or 'localhost' at times
SmellyNAS:~# ssh -L 4200:192.168.118.17:4243 [email protected]
[email protected]'s password:
Last login: Tue Nov 4 10:46:32 2014 from 192.168.118.138
Last login: Tue Nov 4 10:47:28 2014 from smellynas on pts/2
Linux SmellyNAS 2.6.37.6.RNx86_64.2.4 #1 SMP Wed Aug 20 11:41:34 PDT 2014 x86_64 GNU/Linux
SmellyNAS:~# netstat -na | grep LISTEN | grep 4
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN
tcp 0 0 5.171.174.232:6887 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:4200 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:945 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
tcp6 0 0 :::548 :::* LISTEN
tcp6 0 0 ::1:4200 :::* LISTEN
tcp6 0 0 :::443 :::* LISTEN
unix 2 [ ACC ] STREAM LISTENING 7345 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 7474 /var/run/mysqld/mysqld.sock
From here if i launch up CrashPlan it still fails.. I am assuming this is correct as it seems on the NAS that that particular command is not quite correct (or at least on my NAS where it has inverted the ports!)
- I wouldn't have a clue why the command is not fowarding...
So what are my options here?
- i have Ultra 6 and can't move data anywhere as there is too much!
