bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
ghostlobster
Dec 04, 2014Aspirant
I've been working OK for a while. Now, I believe it coincides with the 6.2 system upgrade, VCrashplan..well...crashes. It runs for a few moments, then dies. My crashplan/bin directory is littered with restart log files every about 4 minutes and I cannot figure out why. There is no smoking gun for me to point to. In looking at the crashplan/log directory, I have a few logs in there, but again, no data about the crash. In the engineoutput.log, I'm seeing this:
I don't see anything about a crash there though. What the heck did I miss? I did a remove/reinstall last night, and no luck.
Edit...
I've changed my run.conf to:
And bumped my ulimit number per other posts in this thread. Still crashing and restarting constantly.
Thanks
] CPVERSION = 3.6.4 - 1388642400364 (2014-01-02T06:00:00:364+0000)
[12.04.14 22:00:35.380 INFO main root ] LOCALE = English
[12.04.14 22:00:35.381 INFO main root ] ARGS = [ ]
[12.04.14 22:00:35.381 INFO main root ] *************************************************************
[12.04.14 22:00:35.445 INFO main root ] Adding shutdown hook.
[12.04.14 22:00:35.452 INFO main root ] BEGIN Loading Configuration
[12.04.14 22:00:35.480 INFO main root ] BEGIN Copy Custom
[12.04.14 22:00:35.480 INFO main root ] Directories: [.Custom, custom, /usr/local/crashplan/conf/.Custom, /usr/local/crashplan/conf/custom]
[12.04.14 22:00:35.480 INFO main root ] NOT waiting for custom skin to appear
[12.04.14 22:00:35.481 INFO main root ] NO customizations found.
[12.04.14 22:00:35.481 INFO main root ] END Copy Custom
[12.04.14 22:00:35.484 INFO main root ] Loading from default: /usr/local/crashplan/conf/default.service.xml
[12.04.14 22:00:35.539 INFO main root ] Loading from my xml file=conf/my.service.xml
[12.04.14 22:00:35.601 INFO main root ] Loading ServiceConfig, newInstall=false, version=6, configDateMs=1417694671137, installVersion=1388642400364
[12.04.14 22:00:35.601 INFO main root ] OS = Linux
[12.04.14 22:00:35.734 INFO main root ] AuthorityLocation@441502220[ location=central.crashplanpro.com:443, hideAddress=false ]
[12.04.14 22:00:35.736 INFO main root ] Checking Java memory heap max.
[12.04.14 22:00:35.738 INFO main root ] Previous Java memory max heap size was 1024
[12.04.14 22:00:35.740 INFO main root ] END Loading Configuration
jtux64 Loaded.
Edit...
SRV_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
GUI_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanDesktop -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
Thanks
