bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
f41yaz
Dec 05, 2014Aspirant
oshae wrote: So when you navigated to /usr/local/crashplan and use "ls" are there any files in it?
Make sure you're not doing cd /etc/init.d/crashplan status. "cd" moves between directories. Just /etc/init.d/crashplan status
You would be helping your self an incredible amount if you knew a couple basic Linux commands like cd, ls etc.
I wasn't doing the /etc/.. with cd.
ls for usr/local/crashplan shows:
NAS-FAIYAZZ:~# cd /usr/local/crashplan
NAS-FAIYAZZ:/usr/local/crashplan# ls
backupArchives bin install.vars
ls for /usr/local shows:
bin CrashPlanEngine.pid games lib sbin src
crashplan etc include man share var
ls for /usr shows:
bin games include lib local sbin share src
I know some basis linux commands but my main problem is all of a sudden it has stopped working for no apparent reason and can't seem to get back for it to work. I've tried re-installing but still not working and am really stuck.
i tried command : ps aux | grep BaseName BUT all i get is > root 8424 0.0 0.0 3840 504 pts/0 S+ 21:31 0:00 grep BaseName ???
and for commaned: netstat -an | grep ':424.' I get nothing ???
Shall I reinstall? Do I have to remove the directories?
Thanks for your support!
