bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
ghostlobster
Dec 07, 2014Aspirant
Does anyone have any ideas on this issue, or at least where to look to find out why this is dying on me?
ghostlobster wrote: I've been working OK for a while. Now, I believe it coincides with the 6.2 system upgrade, VCrashplan..well...crashes. It runs for a few moments, then dies. My crashplan/bin directory is littered with restart log files every about 4 minutes and I cannot figure out why. There is no smoking gun for me to point to. In looking at the crashplan/log directory, I have a few logs in there, but again, no data about the crash. In the engineoutput.log, I'm seeing this: ] CPVERSION = 3.6.4 - 1388642400364 (2014-01-02T06:00:00:364+0000)
[12.04.14 22:00:35.380 INFO main root ] LOCALE = English
[12.04.14 22:00:35.381 INFO main root ] ARGS = [ ]
[12.04.14 22:00:35.381 INFO main root ] *************************************************************
[12.04.14 22:00:35.445 INFO main root ] Adding shutdown hook.
[12.04.14 22:00:35.452 INFO main root ] BEGIN Loading Configuration
[12.04.14 22:00:35.480 INFO main root ] BEGIN Copy Custom
[12.04.14 22:00:35.480 INFO main root ] Directories: [.Custom, custom, /usr/local/crashplan/conf/.Custom, /usr/local/crashplan/conf/custom]
[12.04.14 22:00:35.480 INFO main root ] NOT waiting for custom skin to appear
[12.04.14 22:00:35.481 INFO main root ] NO customizations found.
[12.04.14 22:00:35.481 INFO main root ] END Copy Custom
[12.04.14 22:00:35.484 INFO main root ] Loading from default: /usr/local/crashplan/conf/default.service.xml
[12.04.14 22:00:35.539 INFO main root ] Loading from my xml file=conf/my.service.xml
[12.04.14 22:00:35.601 INFO main root ] Loading ServiceConfig, newInstall=false, version=6, configDateMs=1417694671137, installVersion=1388642400364
[12.04.14 22:00:35.601 INFO main root ] OS = Linux
[12.04.14 22:00:35.734 INFO main root ] AuthorityLocation@441502220[ location=central.crashplanpro.com:443, hideAddress=false ]
[12.04.14 22:00:35.736 INFO main root ] Checking Java memory heap max.
[12.04.14 22:00:35.738 INFO main root ] Previous Java memory max heap size was 1024
[12.04.14 22:00:35.740 INFO main root ] END Loading Configuration
jtux64 Loaded.
I don't see anything about a crash there though. What the heck did I miss? I did a remove/reinstall last night, and no luck.
Edit...
I've changed my run.conf to:SRV_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
GUI_JAVA_OPTS="-Dfile.encoding=UTF-8 -Dapp=CrashPlanDesktop -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false"
And bumped my ulimit number per other posts in this thread. Still crashing and restarting constantly.
Thanks
