bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
ghostlobster
Dec 15, 2014Aspirant
mdgm wrote: You last did a factory reset on 6.0.3:
[2013/05/06 14:35:01] Factory default initiated due to new disks (no RAID, no partitions)!
[2013/05/06 14:35:21] Defaulting to X-RAID2 mode, RAID level 5
[2013/05/06 14:35:26] Factory default initiated on ReadyNASOS 6.0.3.
[2013/05/06 13:34:09] Updated from ReadyNASOS 6.0.3 to 6.0.4.
[2013/05/09 04:50:39] Updated from ReadyNASOS 6.0.4 to 6.0.5.
[2013/05/21 07:26:22] Updated from ReadyNASOS 6.0.5 to 6.0.6.
[2013/07/13 09:59:50] Updated from ReadyNASOS 6.0.6 to 6.0.8.
[2013/11/14 18:15:04] Updated from ReadyNASOS 6.0.8 to 6.1.4.
[2014/01/12 16:47:05] Updated from ReadyNASOS 6.1.4 to 6.1.5.
[2014/03/01 08:27:26] Updated from ReadyNASOS 6.1.5 to 6.1.6.
[2014/08/03 10:13:36] Updated from ReadyNASOS 6.1.6 (1391111179) to 6.1.8 (1398980083).
[2014/09/27 12:22:31] Updated from ReadyNASOS 6.1.8 (1398980083) to 6.1.9 (1409791183).
[2014/11/24 18:28:51] Updated from ReadyNASOS 6.1.9 () to 6.2.0 (ReadyNASOS).
I think it would be worth your while to backup your data, do a factory reset and restore your data from backup
Seriously???? That factory reset was performed when the NAS was initially installed. Are you saying that a factory reset is required now? That would be a weekend long project, rebuilding the RAID, restoring backups, and now that we're using local authentication rather than AD integration, and there is no bulk user import facility from a .csv file (that I could find) manually entering all of the users. If I wanted those headaches I would have stuck with the Windows server we had in place.
There has to be a better option other than wipe/restart. There was nothing else in those logs top indicate why this is crashing on us?
