bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
mdgm-ntgr
Dec 15, 2014NETGEAR Employee Retired
Well I guess you could try e.g. 6.2.1-RC3 and see if that helps.
Crash plan must have been installed via SSH. It's possible you might need to enter some additional commands to get it to work.
The factory default is what I would recommend. If you don't want to do that you could perhaps try a defrag and maybe a balance and see if that helps.
When you tested with snapshots and bit-rot protection disabled did you test on a brand new share?
