bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
ghostlobster
Dec 25, 2014Aspirant
Just an FYI, in case anyone else runs into a similar issue. I was seeing the same behavior with this backup on the Windows box...the service kept recycling. I changed the JVM size from 1GB to 1.5 GB, and it's been up and running ever since. Basically, it was out of memory. I dug through the service logs, and there it was, plain as day, Out of Memory. Should have seen it before, but honestly, I didn't know where to begin looking.
So...if your service is restarting and your backups are not completing, and you can't find any reason, check your service log file for an out of Memory condition. If you're getting it, change the java launch parameters to allocate more RAM. Go in 500MB increments until you find the sweet spot.
