bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
tony359
May 30, 2015Apprentice
Hi all,
I'm trying to install CrashPlan on my Pro 6.
I've followed the instructions, everything is ok till step 9. Everything installs, but when I check if the ReadyNAS is listening to port 4200, the answer is NO!
I am not massively skilled with Linux but I reckon CrashPlan has not started. I tried stopping and starting the service, it does not give error messages but I cannot see on the list of services running.
Any help? Java is running.
Enterprise:/usr/local/crashplan/bin# ps aux | grep BaseName
root 4078 0.0 0.0 3840 504 pts/0 S+ 10:02 0:00 grep BaseName
netstat -na | grep LISTEN | grep 42does not produce any output.
Enterprise:/usr/local/crashplan/bin# java -version
java version "1.8.0_33"
Java(TM) SE Embedded Runtime Environment (build 1.8.0_33-b05, headless)
Java HotSpot(TM) Embedded Server VM (build 25.33-b05, mixed mode)
