bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
May 30, 2015Guru - Experienced User
Crashplan for home?
What do you see if you enter
It should be something like this:
ps auxww | grep -i CrashPlanService
root 63 0.1 6.1 873644 126976 ?? SNs Tue03PM 43:01.37 /System/Library/Frameworks/JavaVM.framework/Commands/java -Dapp=CrashPlanService -Xmn10m -Xms15m -Xmx512m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -DCP_USER_NAME= -DCP_USER_HOME= -cp lib/com.backup42.common.jar:lib/com.backup42.service.jar:lib/com.code42.backup.jar:lib/com.code42.bplusj.jar:lib/com.code42.messaging.jar:lib/com.code42.os.jar:lib/com.code42.peer.jar:lib/com.code42.utils.jar:lib/com.jniwrapper.jniwrap.jar:lib/com.jniwrapper.macpack.jar:lib/com.jniwrapper.winpack.jar:lib/jtux.jar:lib/trove-2.0.1.jar:lang com.backup42.service.CrashPlanService
