bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
tony359
May 31, 2015Apprentice
Hi,
As discussed elsewhere, I am now trying to put together an updated step by step guide for installing CP on an OS4 Intel x86 NAS. I hope this could be useful for someone. Please understand that I am not a Linux guru so I may say some nonsense, do not hesitate to point out what is wrong.
Below the tentative. I hope I can come back and amend it while we work on it. Otherwise I'll need the admin's help! :)
I have a question regarding the global Java location for the system. I do not think that using the link I mentioned is correct. It works, but not sure it's the right thing to do.
Also, is there an easier way to install Java by using apt-get?
Thanks everybody.
CrashPlan Headless install - For dummies . Updated for CrashPlan 4.3.0 - 07/07/2015
What is a 'headless' install?
CrashPlan can be installed directly on a NAS. It will run as a service in background. However, we cannot connect a monitor to operate CrashPlan's GUI directly on the NAS. This makes the NAS "Headless". To operate and configure CrashPlan on our NAS we will use CrashPlan for Windows/Mac/Linux and redirect the GUI so it controls the NAS instead.
INTEL x86 based NAS
Step 1: INSTALL SSH
SSH allows the user to open a Linux terminal screen on a Windows/MAC/Linux computer so the NAS can be operated at Linux level.
Install the following add-on http://www.readynas.com/download/addons ... .0-x86.bin by following the below steps:
- open FrontView
- Navigate to Add-Ons
- Click on ADD NEW
- Browse to the file and click UPLOAD AND VERIFY IMAGE
- The NAS will install the add on for you
To SSH into the NAS by putty (open source app)
- Download putty at http://the.earth.li/~sgtatham/putty/lat ... /putty.exe
- putty does not require installation. Double click on the file, type the IP address of your NAS on "HOST NAME (or IP address)". Make sure that CONNECTION TYPE is set to SSH and click OPEN
- Putty may warn you about some security issues, click on OK to continue
- login using root as user name and the password used for the admin user on frontview.
- nothing to do at this stage, just leave the window open.
Step 2: INSTALL JAVA (this is apparently not needed anymore from version 4.2.0 onwards)
- Browse to the Oracle website and download the latest x86 Linux Small Footprint – Headless The download page is: http://www.oracle.com/technetwork/java/ ... index.html
- Save the file on your NAS on the BACKUP share
- Download and install the following add-on: http://minimserver.com/downloads/EJREIn ... as-x86.bin
- The above add-on will install the Java package we have just saved on the BACKUP share. When Java has been installed, switch back to the SSH window (open a new one if you had to reboot the system) and type the following command:
If Java was correctly installed the system will reply with something like
Step 3: INSTALL CrashPlan
Navigate to CrashPlan's website and download the Linux version. Save it on the BACKUP share of your NAS. using wget is easy but getting the URL is not. I believe this is an easier alternative.
Back on the SSH terminal window, type the following commands (assuming that CrashPlan_4.3.0_Linux.tgz is the file you've just downloaded)
(this will list the files currently in your share. Identify the latest CrashPlan file you've just saved)
(replace CrashPlan_4.3.0_Linux.tgz with whatever is the file you've just downloaded)
- Now the file is being copied to the root folder. Navigate to the root folder and extract the archive
(again, replace CrashPlan_4.3.0_Linux.tgz with whatever you've just copied)
Type ls and you will see a folder called CrashPlan-install. Navigate into it by typying
- Run CrashPlan install by typing
You will be asked to accept the EULA conditions. Scroll down (by hitting space to browse an entire page at a time).
- Confirm all the default options but point 4
- CrashPlan will ask a final confirmation
- CrashPlan will now install.
STEP 4: Change the default JAVA location being used by CrashPlan (This is apparently not needed from version 4.2.0 if you just let CrashPlan install its own version of Java)
You will need an FTP client such as FileZilla or WinSCP (both freeware).
On FileZilla create a new profile using the following setup
HOST: your NAS IP
PORT: Leave blank
PROTOCOL: SFTP - SSH File Transfer Protocol
LOGON TYPE: Normal
USER: root
PASSWORD: (your SSH/admin password)
- navigate to CrashPlan configuration file
- Edit install.vars file using your favorite editor (Notepad++ recommended)
locate the following line:
replace the path it with the following: /etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java
the final string will be
Not sure about that, isn't there a less version-dependent link under Linux? If Java is updated the whole thing has to be amended
Save the file and upload it back (FileZilla will detect the changes and will suggest to upload the file)
STEP 5: amend configuration file on the NAS
HOST: your NAS IP
PORT: Leave blank
LOGON TYPE: Normal
USER: root
FileZilla will land in the /root folder. Just browse back to navigate to the actual root (/) folder. Now you can browse/edit files without using Linux and its user-friendly interface :)
I recommend that you make a copy of the file my.service.xml.
Navigate to the following folder:
Make a backup of the file - or rename it
Edit my.service.xml located in /usr/local/crashplan/conf. Use your favorite editor (Notepad++ recommended)
Find the below line
and change it to
(thanks to sdouek for the hint!)
Save the file, FileZilla will detect the changes and will ask you if you want to upload the file.
- Now restart CrashPlan (if it had ever started) by typing on the Terminal window
- Confirm that CrashPlan is running by typing
The system must reply with something like the below
otherwise you will receive a much less interesting answer as the below
In the latter, CrashPlan has not started.
STEP 6: Connect your Windows GUI to your NAS
As mentioned, now we need to configure and manage the 'headless' CrashPlan service on your NAS. It is running but it's not doing anything because it does not know what to do. To do so we will need to fool our Windows system so the CrashPlan GUI connects to the NAS without realising so.
First, download and run the latest Windows CrashPlan client on your Windows PC. Do not run it straight away.
Next, amend the windows client's configuration. This is your Windows computer, not the NAS!
Navigate to the client's installation folder and look for a file called ui.properties.
It should be on C:\Program Files\CrashPlan\conf\ui.properties
Edit the file by using a decent editor, the default Notepad won't work well. If you do not have Notepad++ or similar, you can open it by using WordPad which is installed by default under windows.
Find the following line:
Replace it with:
Next find the following line
replace it with
Save and close the file.
Next, confirm that the relevant ports are being used on the NAS. Switch to the SSH terminal window (or open a new one). Type:
the output should show that port 4243 is listening on the local address
if you get no output, then we have a problem. Make sure that CrashPlan is running as described above.
From version 4.3.0 there is an additional step to be performed.
1 . Confirm your Windows GUI is version 4.3 and it is NOT running (you may have to kill the process "CrashPlanDesktop.exe" running in the background)
2. Connect to the NAS by FTP using ROOT credentials.
3.Copy the file .ui_info from your NAS to your computer:
.....On the NAS: .ui_info on NAS is probably located /var/lib/crashplan (unless you changed it from the default when installing)
.....On the PC: .uni_info on your desktop is located on C:\ProgramData\CrashPlan. (Rename your old .uni_info to .uni_info.orig)
Open the CrashPlan GUI on your Windows PC. It should now automatically connect to the NAS.
Click on SETTINGS/GENERAL. The NAS' name should be displayed under "Name for this computer".
Now you are configuring the CrashPlan service on the NAS. Remember: every time you need to do so, you will need to open a tunnel by opening putty as described above. If you saved the configuration (recommended), just click on ReadyNAS CrashPlan click LOAD and then OPEN. This will save you typing the same information every time.
Useful Documents/Tweaks
Instructions for the cache are here: http://support.code42.com/CrashPlan/Lat ... _Directory
You do need to preserve the linux EOL convention (either edit on the NAS, or use something like notepad++). The cache can become quite large.
Instructions for the archive directory are here: http://support.code42.com/CrashPlan/Lat ... _Is_Stored
Note this only matters of you are saving backups for other machines on the NAS (e.g., using the crashplan "friend backup" feature).
How to open a tunnel by using putty - useful to control CrashPlan remotely without having to port-forward anything more than port 22 (SSH port)
- Close all the open putty windows
- Open putty again. On the main "PUTTY CONFIGURATION" windows click on SSH and then TUNNELS on the left hand side.
- Type 4200 on the SOURCE PORT field
- Type localhost:4243 on the DESTINATION field.
- Click on ADD
Navigate to SESSION again and type the IP address of your NAS. Make sure the CONNECTION TYPE is set to SSH and port number is 22.
Because this will need to be done before running the CrashPlan GUI, I suggest you save the configuration before you connect to the NAS.
Type "ReadyNAS CrashPlan" on the SAVED SESSIONS field. Click on SAVE.
Now you can connect and establish the tunnel by clicking OPEN. Log in as usual.
From version 4.3.0 onwards there is an extra step:
edit C:\ProgramData\CrashPlan\conf\ui_username.properties (username will be your actual username)
Change
With
Various hints and tools
#As of CrashPlan 4.2, CrashPlan will install their Java to run with their software on you NAS. There is no need to install a new Java on your whole NAS.
#JAVACOMMON=/usr/local/crashplan/jre/bin/java
#CrashPlan tests their software with that specific Java. (Unless you want to do their Quality Assurance for them on a new Java :) )
#Seeing What Port NAS is Listening to.
netstat -na | grep LISTEN | grep 42
#Return code should look something like this:
tcp6 0 0 :::4242 :::* LISTEN
tcp6 0 0 ::ffff:YOUR.NAS.IP.ADDRESS:4243 :::* LISTEN
#Starting,Stopping CrashPlan.
#/usr/local/crashplan/bin/
./CrashPlanEngine stop
./CrashPlanEngine status
./CrashPlanEngine start
./CrashPlanEngine restart
OR
/etc/init.d/crashplan [same options as above]
#Unpacking CrashPlan to install.
#/root/
tar -xvf CrashPlan_4.3.0_Linux.tgz
#(4.3.0 change to package number you are installing)
#Installing and Uninstalling CrashPlan (This will not uninstall your .ui_info or .identity file).
#/root/CrashPlan-install/
./CrashPlan-install/install.sh
./CrashPlan-install/uninstall.sh -i /usr/local/crashplan/
#/usr/local/crashplan/conf/my.service.xml
<serviceHost>YOUR.NAS.IP.ADDRESS</serviceHost>
OR
#To have CrashPlan listen on all network interfaces and thus accepting GUI connections from any computer on your home network.
<serviceHost>0.0.0.0</serviceHost>
#If Watch file system in real time" is not working CrashPlan suggested changes so that it works on a NAS.
#/etc/sysctl.conf
fs.inotify.max_user_watches=1048576
#Increasing Memory Value to CrashPlan Engine.
#Go to CrashPlan on PC and Double Click Home Icon in Upper Right Hand Corner
#Value should be in memory increments of 64, increasing value too high will stop CrashPlan from running. The upper limit on my NAS PRO Business is 3072 and I have 8 GB of Ram installed.
java mx "value"
OR
#Stop CrashPlan
#Edit /usr/local/crashplan/bin/run.conf in SRV_JAVA_OPTS change "-Xmx3072m" to desired value.
#Start CrashPlan
#Configuring CrashPlan Backup set to Exclude all Directories Named "Recycle Bin".
#Located in Settings-Backup-File exclusions:-Configure (Make sure "Regular Expressions" is checked).
./*Recycle Bin.*
#Another way to check if the CrashPlan service is running in your PC.
ps auxww |grep -i CrashPlanService
#Return code should be something like this:
root 19952 80.3 7.4 3623440 611904 ? SNl 08:17 400:32 /usr/local/crashplan/jre/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx3072m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
root 23519 0.0 0.0 4104 504 pts/0 S+ 16:35 0:00 grep -i CrashPlanService
Thanks everybody.
INTEL x86 based NAS
Step 1: INSTALL SSH
- open FrontView
- Click on ADD NEW
java -version
java version "1.8.0_33"
Java(TM) SE Embedded Runtime Environment (build 1.8.0_33-b05, headless)
Java HotSpot(TM) Embedded Server VM (build 25.33-b05, mixed mode)
cd /backup
ls
cp CrashPlan_4.3.0_Linux.tgz /root]
cd /root
cd CrashPlan-install
./install.sh
Do you accept and agree to be bound by the EULA? (yes/no) yes
What directory do you wish to install CrashPlan to? [/usr/local/crashplan]
What directory do you wish to link the CrashPlan executable to? [/usr/local/bin]
What directory do you wish to store backups in? [/usr/local/var/crashplan] /crash-backup
What directory contains your SYSV init scripts? [/etc/init.d]
What directory contains your runlevel init links? [/etc/rc2.d]
Your selections:
CrashPlan will install to: /usr/local/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /crash-backup
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Is this correct? (y/n) [y] y
HOST: your NAS IP
PORT: Leave blank
LOGON TYPE: Normal
USER: root
JAVACOMMON=/usr/local/ (cannot remember the original path!)
JAVACOMMON=/etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java
HOST: your NAS IP
PORT: Leave blank
LOGON TYPE: Normal
USER: root
my.service.xml
Find the below line
<serviceHost>127.0.0.1</serviceHost>
and change it to
<serviceHost>Your.NAS.IP.ADDRESS</serviceHost>.
./usr/local/crashplan/bin/CrashPlanEngine restart
root 4714 16.3 19.5 1262344 402020 ? SNl May30 213:54 /etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
root 16791 0.0 0.0 3840 504 pts/0 S+ 08:54 0:00 grep -i crashplanservice
root 7136 0.0 0.0 3840 500 pts/0 S+ 10:29 0:00 grep -i crashplanservice
#servicePort=4242
Replace it with:
servicePort=4200
#serviceHost=127.0.0.1
replace it with
serviceHost=Your.NAS.IP.ADDRESS
username$ netstat -na | grep LISTEN | grep 42
tcp4 0 0 *.4242 *.* LISTEN
tcp4 0 0 127.0.0.1.4243 *.* LISTEN
- Click on ADD
Change
servicePort=4243
With
servicePort=4200
OR
#/root/
OR
#/etc/sysctl.conf
java mx "value"
OR
#Stop CrashPlan
#Start CrashPlan
./*Recycle Bin.*
