bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Jul 08, 2015Guru - Experienced User
If you remove all your disks and put in a scratch disk, the system will do a factory install. You can then power down and re-install your original disks in their original slots.
This is safe (as long as you don't drop a disk, etc).
Migrating part of the OS partition from the scratch disk to the main disks would be dicey, and you should certainly be prepared to do a full restore if you attempt that. But you could get some useful information w/o doing that (answers to "what Java was originally installed" and the like).
