bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
sdouek
Jul 13, 2015Guide
1) What NAS are you installing Crashplan to ? (This is very important, Not all NAS units can handle CrashPlan).
2) If you are installing CrashPlan 4.3 it will install its own java. You can check by going to /root/CrashPlan-install this is where you unpacked the tgz file to. You should see jre-7u45-linux-x64.tgz, this is the java CrashPlan downloads when you install CrashPlan.
3) To Further check go to /usr/local/crashplan/jre/bin
type in java -version
Should get this:
Java(TM) SE Embedded Runtime Environment (build 1.7.0_75-b13, headless)
Java HotSpot(TM) Embedded Client VM (build 24.75-b04, mixed mode).
4) As far as restoring the old Global Java - short of doing a factory reset I don't know and I have a post asking for help but no one seems to know.
JAVA: re-intsalling on ReadyNAS Bus PRO
Should get this:
