bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
sdouek
Jul 14, 2015Guide
If the EJRE addon is already installed on your system do not uninstall it, it is still needed globally and as per MinimServer.
Uninstalling the Java runtime
To remove the EJRE installation from your ReadyNAS, remove the EJRE Installer add-on. This removes the installed EJRE files, but doesn't remove the original EJRE .tar.gz file from the backup share.
