bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like...
Oct 13, 2015Guru - Experienced User
Lex_Mih wrote:
Hello,
The only thing I noticed that changed since the last version of Crashplan is to copy also the IP on the right of the code in the .ui_info file from the NAS. (the IP will most likely be the one of your NAS).
I think this isn't needed if you use putty to tunnel the crashplan client connection to the NAS. At least I haven't needed it.
WolfieCA
Oct 13, 2015Aspirant
Thanks for the valuable info.
I guess I am to presume that if I don't have the .ui_info file from the original setup, I am up a creek, so to speak.
I set this up in October of 2012 and I haven't touched it since. Back then, there was not any info I ready about saving that file locally.
- sdouekOct 13, 2015Guide
WolfieCA wrote:Thanks for the valuable info.
No just adopt the old nas computer.
Crashplan how to adopt a computer
- WolfieCAOct 13, 2015Aspirant
Just ran across this ... is there any downside to this method considering I am the only user?
CrashPlan App Version 4.3 And Later
For the CrashPlan app version 4.3 and later, you can install the CrashPlan app per user. This installation allows you to add the mapped drive to your backup file selection just as you would any other drive. If the CrashPlan app is already installed for everyone on your computer, you can completely uninstall the CrashPlan app and reinstall per user instead.
