chaug
Jan 16, 2017Aspirant
Crashplan upgrade problems again
Once again, my Crashplan crashes when trying to perform the automatic upgrade. (This time it's trying to upgrade to crashplan 4.8.) Unfortunately, the reasons for the upgrade failure seem to be diffe...
Jan 18, 2017Guru - Experienced User
chaug wrote:
- making wget ignote certificates by adding check_certificate = off to /etc/wgetrc
I think that didn't take, since the errors are about certificate checks (ERROR: certificate common name `*.crashplan.com' doesn't match requested host)
I think you needed to do this by creating a .wgetrc in /root that has check_certificate = off
Though 4.8 hasn't reached my system yet, so I can't say for sure.
EDIT - I just realized that was from the 4.7 upgrade, not this one. Are you sure this is failing on the NAS (not the PC?) Perhaps check the NAS with
cat history.log.0 | grep update
