satiated
Mar 31, 2016Tutor
Crashplan wants Java downgrade to 1.7?
So I'm familiar with this thread: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/985781#M10762, which is about the pain everyone had late last year when ...
Mar 31, 2016Guru - Experienced User
My pro-6 is running 4.2.28 firmware. I'd installed Java 1.8 in /usr/local/bin (which is still there).
Crashplan sucessfully upgraded on 25 March to version 4.6.0. It has installed Java 1.7 in /usr/local/crashplan/jre - not sure exactly when that happened, but I am thinking it was 14 March.
Backups are happening normally, including files successfully backed up today.
- skim32Apr 06, 2016Tutor
I am still having trouble with my Crashplan updating. The log shows the following:
Wed Apr 6 08:52:20 EDT 2016 : Sourcing ../../install.vars... Wed Apr 6 08:52:20 EDT 2016 : Found INITDIR=/etc/init.d... ====================================================== Wed Apr 6 08:52:20 EDT 2016 : Current CrashPlan Backup Engine: root 25385 1 2 08:21 ? 00:00:47 /usr/local/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService Wed Apr 6 08:52:20 EDT 2016 : Stopping using /etc/init.d/crashplan... Stopping CrashPlan Engine ... OK Wed Apr 6 08:52:30 EDT 2016 : Ensuring the UpgradeUI is not running. Wed Apr 6 08:52:30 EDT 2016 : UpgradeUI is shut down. Wed Apr 6 08:52:30 EDT 2016 : JAVACOMMON is set: /usr/local/bin/java Wed Apr 6 08:52:30 EDT 2016 : Current Java Version: 1.8 Wed Apr 6 08:52:31 EDT 2016: The Current java is not compatible. Embedding a compatible version. Wed Apr 6 08:52:31 EDT 2016 : Download JVM from http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz Wed Apr 6 08:52:31 EDT 2016 : downloading the JRE using /usr/bin/wget wget: Unknown command `eck_certificate' in /root/.wgetrc at line 1. Wed Apr 6 08:52:31 EDT 2016 : Unable to download JRE from http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz; please check network connection Wed Apr 6 08:52:31 EDT 2016 : Starting using /etc/init.d/crashplan... Starting CrashPlan Engine ... Using standard startup OK
A little background. I too upgraded to 1.8 a few months ago because of the upgrade failures we expereienced last time. I also applied the glib6.2.13 upgrade as described here. So I was good for a while until 4.6. I've seen some previous posts suggesting to edit .wgetrc file to disable certificate checks, but that didnt' work for me. Maybe I did it wrong. But this is what i followed. In my $HOME directory there was no .wgetrc file so I ended up just creating one. Do I have to bounce the readynas for it to take affect? I am running a ReadyNAS Ultra + 4. Anyhow, my update keeps failing and my partition keeps getting filled up. Any help would be appreciated.
