satiated
Mar 31, 2016Tutor
Crashplan wants Java downgrade to 1.7?
So I'm familiar with this thread: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/985781#M10762, which is about the pain everyone had late last year when ...
satiated
Apr 07, 2016Tutor
I downloaded the jre manually from the link Crashplan was trying to us, extracted it to the /usr/local/crashplan/jre directory, and changed install.vars to point to it. Now I'm getting this error:
nice: /usr/local/crashplan/jre/bin: Permission denied
Which I assume is because whatever user the crashplan service is running under doesn't have access to the java directory. But the permissions on that directory have read and execute for group and all users, owned by root. So I'm a bit confused now.
I would say you could just download it manually yourself as I have, but you may end up with the same problem.
skim32
Apr 13, 2016Tutor
I got it to work following this thread. I had followed it before but i had a typo in the string I added in the .wgetrc file (not used to vi). Anyways. Hopefully this helps you.
