freewun13
Oct 19, 2018Aspirant
Cron Jobs after NVX System Reset
Hi All, When I got my NVX back in 2009 I started playing around with cron jobs to do a few things and they worked fine. I just recently did a system reset and I saved all the text associated with...
- Oct 22, 2018
Did you do the apt-get update again (after you modified sources.list)?
Oct 19, 2018Guru - Experienced User
freewun13 wrote:
-bash: $: command not found
I get this:
PRO:~# crontab -e
no crontab for root - using an empty one
/bin/sh: /usr/bin/editor: No such file or directory
crontab: "/usr/bin/editor" exited with status 127
You do need to log in as root. crontab should be in /usr/bin
PRO:~# which crontab
/usr/bin/crontab
freewun13
LIke I said...this was a long time ago so I have even less of an idea now! From Putty....
Using username "root".
[email protected]'s password:
Last login: Fri Oct 19 21:36:16 2018 from 192.168.1.10
Last login: Fri Oct 19 21:38:41 2018 from 192.168.1.10 on pts/0
Linux NAS 2.6.37.6.RNx86_32.1.4 #1 Thu May 28 16:18:23 PDT 2015 i686 GNU/Linux
NAS:~# cd /usr/bin/
NAS:/usr/bin# ~# which crontab
-bash: ~#: command not found
NAS:/usr/bin# crontab -e
NAS:/usr/bin#
- StephenBOct 19, 2018Guru - Experienced User
freewun13 wrote:
NAS:~# cd /usr/bin/
-bash: ~#: command not foundSomething is wrong here. If you have a spare disk, try doing a factory install with only that disk in place. Then see if you get the same result.
What firmware are you running?
- freewun13Oct 19, 2018Aspirant
The last one published.... RAIDiator-x86-4.2.31
OK...changed disk and changed position of the single disk.....
NAS:~# crontab -e
crontab: "/usr/bin/editor" exited with status 127NAS:~# which crontab
/usr/bin/crontabLooks the same to me.
Still dont know how to create pingmedia.sh file!?
It appears nano isnt installed and wont install....
NAS:~# sudo apt-get update
Hit http://www.readynas.com 4.2.31/ Release.gpg
Ign http://www.readynas.com 4.2.31/ Translation-en_US
Ign http://www.readynas.com 4.2.31/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.31/ Packages
Reading package lists... Done
NAS:~# sudo apt-get install nano
Building dependency tree... Done
E: Couldn't find package nano- StephenBOct 20, 2018Guru - Experienced User
Why are you using sudo? If you are using root (as you should be) it isn't needed.
On nano, look here: https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/Can-t-install-nano/m-p/931919#M12674
