freewun13
Oct 19, 2018Aspirant
Cron Jobs after NVX System Reset
Hi All, When I got my NVX back in 2009 I started playing around with cron jobs to do a few things and they worked fine. I just recently did a system reset and I saved all the text associated with...
- Oct 22, 2018
Did you do the apt-get update again (after you modified sources.list)?
freewun13
Oct 21, 2018Aspirant
Created a new file as suggested and made it Unix format in the EOL conversion before saving. Copied it to /etc/apt/sources.list successfully and then....
NAS:/# apt-get install nano
Reading package lists... Done
Building dependency tree... Done
E: Couldn't find package nano
I dont seem to be progressing anywhere with this!
Oct 22, 2018Guru - Experienced User
