GAPP
Apr 05, 2014Aspirant
Crontab won't run.
So I got flexget together with Transmission, to download series etc itself. It used to work, but lately I have to execute the job myself, which is really annoying. I want everything to run automatical...
GAPP
Apr 13, 2014Aspirant
Not sure if it's executable or not, I'm not experienced with this system. If I run the flexget execute command, it executes the command correctly though, which is why I thought it would work.
I just did this now:
Can I type something to test the crontab, to see if it works, or do I just wait 6 hours every time to check? :)
# chmod +x /usr/local/bin/flexget
