StephensHomes
Nov 19, 2015Aspirant
Daisy Chain RN102
I am currently at 70% of my 2TB NAS102 (2-bay) and I was under the impression that I can daisy chain another NAS102 to my current system. Like to know before I invest in another unit with drives.
- Nov 19, 2015
No, you can't. There's an expansion chassis for the x86 platforms, but that isn't available for you.
You can have 2 RN102 on the same network, but they'd be independent. You can also get an RN104 (or any other OS6 NAS) and migrate your existing disks.
Nov 19, 2015Guru - Experienced User
- StephensHomesNov 19, 2015Aspirant
OK, then a followup question: If I get two larger HDs, then replace them one at a time allowing the new drive to sync with the older. Is this a possibility?
- mdgm-ntgrNov 19, 2015NETGEAR Employee Retired
The volume will expand as a result of doing that (assuming you are using the default X-RAID).
- StephenBNov 19, 2015Guru - Experienced User
Yes (after the second disk is upgraded of course).
But the RN104 + one new drive might be cheaper for you. And it would have one open slot for expansion later. Perhaps price them both out and see which is better for you.
For instance, if you have 2x3TB WD30EFRX in your RN102 you can get to 6 TB two ways.
-RN104 with 3x3TB. That would cost ~$330 total (today's amazon pricing)
RN104 chassis: $219.99
1 more WD30EFRX: $109.99
-RN102 with 2x6TB. That would cost ~$500
2 WD60EFRX: $249 each
