mslaterhk
Sep 14, 2015Aspirant
Data recovery nightmare
Ok so I'm usually a pretty level-headed guy but this has me sweating - hope someone can help... QUESTION: If ReadyNas has somehow over-written (MBR?) root folder structure of logical volume, and...
- Sep 14, 2015
What you are looking at is the 4GB OS partition.
You will need to install mdadm and lvm2 if they are not already on your system# apt-get install mdadm # apt-get install lvm2
If you have not already you need to start the RAID
# mdadm --assemble --scan
We use LVM on legacy ReadyNAS so you need to do
# vgscan # vgchange -a y
Then you should be able to mount the volume
# mount /dev/c/c /mnt
where /mnt is the mountpoint (could be anything, needs to be an empty directory).
On ubuntu you would need to put sudo at the start of these commands, I think.
mdgm-ntgr
Sep 14, 2015NETGEAR Employee Retired
