mslaterhk's avatar
mslaterhk
Data recovery nightmare
Ok so I'm usually a pretty level-headed guy but this has me sweating - hope someone can help...   QUESTION: If ReadyNas has somehow over-written (MBR?) root folder structure of logical volume, and...
  • mdgm-ntgr's avatar
    Sep 14, 2015
    What you are looking at is the 4GB OS partition.
    You will need to install mdadm and lvm2 if they are not already on your system
    # apt-get install mdadm
    # apt-get install lvm2
    If you have not already you need to start the RAID
    # mdadm --assemble --scan
    We use LVM on legacy ReadyNAS so you need to do
    # vgscan
    # vgchange -a y
    Then you should be able to mount the volume
    # mount /dev/c/c /mnt
    where /mnt is the mountpoint (could be anything, needs to be an empty directory).
    On ubuntu you would need to put sudo at the start of these commands, I think.
ProSupport for Business
