azerva
Jul 24, 2015Tutor
Data Volume Lost after Disk Replace #25483643
Hello ReadyNAS Community,
after a disk failure (disk 3), I replaced this disk. A volume resynchronization was started automatically. However, this resynchronisation failed with no obvious errors and now the entire data volume is unavailable. Can anyone please provide any help as to how to try to rebuid this volume or make it available again?
Regards
Alex
- azervaTutor
Hi,
I still have access via HTTP GUI and SSH. I don't know how good the logs will be, but I will provide then nonetheless. I'm not sure how tho, can't seem to find an attachment button around here.
- vandermerweMaster
I don't suppose you have a backup of the data on the volume?
- azervaTutor
vandermerwe wrote:I don't suppose you have a backup of the data on the volume?
Hi,
well no. It's quite a lot of data, was around 5 TB (I had 4 x 2 TB drives), so not actually a lot of space to back it up twice. The NAS was supposed to be the "redundant" backup ;)
So I'm open to any suggestions.
- vandermerweMaster
Sending logs is described here, you just download them from the nas then email them in:
http://kb.netgear.com/app/answers/detail/a_id/21543
There are many scenarios that a redundant volume does not offer protection against, therefore backups are essential.
What model readynas is it?
I think you need to ask Netgear support to look to look at this, open a support case and be prepared to pay.
- azervaTutor
Hi guys,
update on the whole situation. Netgear Support recommended cloning the disk with ddrescue. I did this, the process finished with 4 errors. Below is the log file.
# Command line: ddrescue -fv /dev/sdb /dev/sda ddrescue.log # current_pos current_status 0x14419EC7C00 + # pos size status 0x00000000 0x139A33C4000 + 0x139A33C4000 0x00001000 - 0x139A33C5000 0x00004000 + 0x139A33C9000 0x00001000 - 0x139A33CA000 0xA76AF6000 + 0x14419EC0000 0x00001000 - 0x14419EC1000 0x00005000 + 0x14419EC6000 0x00002000 - 0x14419EC8000 0x8DA724E000 +
If I am reading this correctly, there are 4 relatively small areas (designated by the - at the end which are bad). I tried to start ReadyNAS with disks 1, 2 and the cloned disk 4, however this didn't work.
Are there any additional steps I need to consider? Should I consider re-running ddrescue using the -r option for more retries? Or is there a command to try to re-detect the RAID volume?
Thanks for any hints.
Alex
- vandermerweMaster
Are support not following up on this case?
Did they offer you data recovery services?
- JennCNETGEAR Employee Retired
Hello azerva,
I strongly recommend not to touch anything but just follow thier instructions. I don't think booting up the NAS with the remaining disks along with the cloned one will rebuild the RAID and get you access the data right away, there are still few steps they will have to do once you have the disk cloned. Please contact the support center to continue with it.
