whoopus
Mar 12, 2012Aspirant
"DDB18 power is out of normal range" error (#18126676)
Okay, I have to vent. My ReadyNas NV+ and my ReadyNas 2100 have performed flawlessly. I have been a ReadyNas user for many years with 0 problems. These devices just "worked". Totally trouble free....
mdgm-ntgr
Mar 12, 2012NETGEAR Employee Retired
Hi Mark you should edit the thread title (i.e. subject of first post in the thread) to include your current case number. That way if a NetGear support representative comes across this thread it will be easier for him/her to help you.
Also when did the unit first start experiencing issues? If NetGear approves a RMA for a new unit, if possible (close enough to purchase) it's best to exchange it via the reseller for a new unit rather than a refurbished one. If the issues started close to the purchase date they should have given you this advice.
It wouldn't even go into the boot menu?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
There is a bug fixed in 4.2.20. System > Update > Remote or automatic updates would have prompted you to update to 4.2.16 then to 4.2.19.
I'd recommend 4.2.20-T40 (http://www.readynas.com/forum/viewtopic.php?f=51&t=57193) which appears to be very close to a production release.
Often that can be due to a disk not syncing properly for whatever reason. If this is the case it shows up in the logs zip file (Status > Logs > Download all logs). Did they check for that?
Ouch! That is a bad run. Hopefully NetGear support can get this sorted quickly.
whoopus wrote: My first unit shut down with no explanation and then would not boot.
whoopus wrote:
The second unit upgraded from .15 to .19 and froze (it seems that you can't upgrade from .15 to .19).
whoopus wrote:
So support cleans up the mess only to find out that now the unit won't expand the volume after I exchange my hard drives for larger ones.
whoopus wrote:
Well, guess what, I get a "DDB18 power is out of normal range [expected: 1.80 current: 1.90]." message every 30 minutes. From what I read, this is a hardware issue and guess what...I get to go through the RMA process.....AGAIN.
