maniac
Sep 05, 2013Aspirant
Dead Readynas - extract data
Hi, My readynas seems to have died. Literally no response when I try and turn it on. I've got as far as checking the fuse on the plug. Firstly, any suggestions on what else I should check, S...
Sep 05, 2013Guru - Experienced User
Linux Reader is Windows software. It only works if you have two disks (xraid). Since your profile said duo, I was assuming duo v1 (as I said in the original post).
However, you apparently have a different NAS. So let's start with "What NAS do you have?" This link is really helpful if your label says duo or nv+: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
