maniac
Sep 05, 2013Aspirant
Dead Readynas - extract data
Hi, My readynas seems to have died. Literally no response when I try and turn it on. I've got as far as checking the fuse on the plug. Firstly, any suggestions on what else I should check, S...
Sep 05, 2013Guru - Experienced User
There is a guide to mounting the v1 drives here: http://home.bott.ca/webserver/?p=306 But dbott's server appears down right now.
My guess is that you have a failed power supply, hopefully Netgear will get new hardware to you quickly.
