TheCHIMP_net
Dec 25, 2008Aspirant
Default Admin/Netgear1 Logon Doesnt Work (#8463338)
Hello Forum Long time reader, finally got the ReadyNas Duo 2150 for Chirstmas today! Very excited and was already planning my "wow, this set up incredibly easy" post of recommendation when I got to...
stretch1
Dec 27, 2008Aspirant
@ TheCHIMP
The "error message" isn't actually an error message. The login dialogue box always says that. I only just noticed.
The revert to factory defaults should have reset the password (i think).
If you're always immediately returning to the login prompt then I can only assume that something is interfering with the log in process.
Some suggestions:
Check that your PC firewall has an exception to allow the NAS through.
Check IE's security settings.
Some suggestions:
